AMD Radeon Uncovered: AMD Fluid Motion Frames
Looking to expand your knowledge of AMD PC hardware? If so, you are in the right place! Our AMD Radeon Uncovered series showcases all the incredible tech that comes with an AMD Radeon GPU. In this blog post, we’re taking a closer look at AMD Fluid Motion Frames or AFMF 2.1.
What is AMD Fluid Motion Frames?
AMD Fluid Motion Frames is a frame generation technology. It will increase FPS and smooth out your gaming by adding in additional frames in real time. On average, this delivers up to 2.5 times higher frame rates on AFMF supported games. As a result, you can enjoy incredible visual fidelity and better responsiveness.
The latest version is AFMF 2.1, which comes with a range of AI-optimised updates. This improves quality, reduces latency, and facilitates better performance. Better yet, you can even fine-tune settings to best suit your gaming needs!
This tech is integrated with AMD HYPR-RX. As such, you can easily enable AMD Fluid Motion Frames and other performance-orientated features.
Supported Games
AMD Fluid Motion Frame is supported by a wide range of popular titles. This includes:
  • Baldur’s Gate 3
  • Warhammer 40K: Space Marine II
  • F1 24
  • Forza Horizon 5
  • No Rest for the Wicked
Baldur's Gate 3
Forza Horizon 5: Drive Across Mexico with all Your Friends
The Imperium Needs You - Warhammer 40K: Space Marine 2
How to Enable AFMF 2.1
There are two ways to enable AMD Fluid Motion Frames, depending on whether you have a Radeon RX 6000 Series or RX 7000 (and newer) Series graphics card.
Enable with RX 6000
To enjoy AFMF 2.1 on AMD Radeon RX 6000 Series graphics cards, you will need to enable this feature manually. To do this, open the AMD Software: Adrenalin Edition application. Navigate to the graphics sub-tab and look for the gaming section. In here, look for AFMF on the list of features and toggle the slider to “enabled”.
This will activate AMD Fluid Motion Frames on a global scale and apply it across all games. Alternatively, you can choose to enable it on a per-game basis in the Games sub-tab.
Enable with RX 7000 and Newer
The other method is available to all AMD graphics cards that support HYPR-RX Profiles, the AMD Radeon RX 7000 Series and newer. Once again, you will need to open the AMD Software: Adrenalin Edition application. This time, select HYPR-RX Profile on the interface. This is a one-click solution that will activate AFMF 2.1 and multiple other features to optimise your gaming.
AFMF 2.1 Hardware Requirements
There are a few hardware and software requirements to run AMD Fluid Motion Frames. Here is what you need from your gaming PC and set-up:
SpecificationRequirement
HardwareAMD Radeon RX 7000 Series graphics cards (desktop and mobile) and AMD Ryzen 7000 Series Processors with Radeon 700M Series graphics, and higher (desktop and mobile) with support for AMD HYPR-RX and AFMF 2 borderless full screen mode.
AMD Radeon RX 6000 Series graphics cards (desktop and mobile) with support for exclusive full screen mode only.
AMD FreeSync technology monitor recommended
SoftwareAMD Software: Adrenalin Edition™ 25.3.1 and above.
VSync disabled in both in-driver and in-game settings.
API SupportMicrosoft DirectX 11 and 12, Vulkan, and OpenGL games.
Operating SystemWindows 11 / 10
Looking to Use AFMF 2.1?
Looking to boost your gaming with AMD Fluid Motion Frames but are in need of an upgrade? We have a selection of gaming PCs that more than meet the requirements to run this game enhancing software. Plus, we’ve picked out a few FreeSync enabled monitors too, to ensure your set-up is fully ready to deliver AFMF 2.1!
OcUK Gaming Kite - AMD Ryzen 7 7700, Radeon RX 9060 XT Gaming PC
OcUK Gaming Kite – AMD Ryzen 7 7700, Radeon RX 9060 XT Gaming PC
SYS-OCG-00070
★★★★★ (5)
£1449.95
(incl. VAT)
FREE SHIPPING
out of stock
ADD TO BASKET
OcUK Gaming Falcon - AMD Ryzen 7 7800X3D - Radeon RX 9070 XT Gaming PC
OcUK Gaming Falcon – AMD Ryzen 7 7800X3D – Radeon RX 9070 XT Gaming PC
FS-1FH-OG
★★★★★ (5)
£2299.99
(incl. VAT)
FREE SHIPPING
out of stock
ADD TO BASKET
OcUK Gaming Vulture - Intel Core Ultra 7 270K Radeon RX 9070 XT Gaming PC
OcUK Gaming Vulture – Intel Core Ultra 7 270K Radeon RX 9070 XT Gaming PC
FS-1EV-OG
★★★★★ (5)
£2099.99
(incl. VAT)
FREE SHIPPING
out of stock
ADD TO BASKET
Gigabyte 24
Gigabyte 24″ G24F-2 1920×1080 SS IPS 165Hz 1ms FreeSync Widescreen Gaming Monitor
MO-00Z-GI
★★★★★ (5)
£99.95
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
MSI 25
MSI 25″ MAG 255F E20 1920×1080 Rapid IPS 200Hz 0.5ms A-Sync Widescreen Gaming Monitor
MON-MSI-04655
★★★★★ (5)
£108.95
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
Learn More About AMD GPUs
AMD Radeon Uncovered: AMD Radeon Anti-Lag
AMD Radeon Uncovered: AMD Software: Adrenalin Edition
AMD Radeon Uncovered: AMD FSR
Are You Using AMD Fluid Motion Frames?
Let us know in the comments below how AFMF 2.1 is improving your gaming!
0 0 votes
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
