Are you in the market for a cube PC case? If so, lucky you! These cases are where cutting-edge performance meets a compact form factor.
We all game, and we all lead busy lives too. For the PC builder who enjoys the fast lane, a chassis of the right size and stature can be a real game changer.
Cube PC Cases
Gaming PC cases are more than just a pretty frame for your powerful hardware (though that too is awesome!). They directly contribute to the functionality and capability of your PC build.
Experienced gamers gravitate toward cube PC cases for their portability. While gaming on the go is thought to be a battle between gaming laptops and handheld devices, a square-shaped hat can easily be thrown into the ring here.
After all, we gamers are often busy with LAN parties, conventions, or even just standard IRL commitments. A cube PC case can quite comfortably join you in all your adventures.
Of course, cube-shaped cases can be more easily integrated into an existing set-up, too. The dimensions can be compact, so finding a good place to position your computer is usually a breeze. Plus, there’s no compromise on hardware, either. Impressive graphics cards, power supply units, and cooling solutions can all be installed inside.
So, surely there’s a downside somewhere here? Well, beyond double-checking the size of your chosen hardware, not really! Things are pretty nifty across the board. Don’t believe us? Take a look at our best cube PC cases!
be quiet! Light Base 500 LX ARGB Mid Tower PC Case
We’re coming out swinging with the be quiet! Light Base 500 LX PC case, which was specially engineered to help you build a showcase PC. The tempered glass front and side panels provide a 270-degree panoramic view of your components, accented further by ARGB lighting and excellent cable management solutions. On the hardware side, this case supports ATX motherboards and has clearance for powerful GPUs up to 400mm long and CPU coolers 185mm high. Put simply, you’ve got plenty of room to build something special and then unabashedly show it off!
Be Quiet Light Base 500 LX ARGB Midi Tower Case - Black
Be Quiet Light Base 500 LX ARGB Midi Tower Case – Black
CAS-BEQ-06471
★★★★★ (5)
£119.95
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
Montech KING 95 PRO Mid-Tower PC Case
A chassis with unrivalled aesthetics, the Montech King 95 PRO PC Case is brimming with personality. This mid-tower PC case boasts a dual-chamber design, supporting a wide range of hardware configurations. This benefits air circulation and cooling too, as there’s more breathing room for components and cable routing! ATX motherboards are supported by the backplate, and there are two locations to install an ATX PSU. Meanwhile, the second mount can be utilised for a drive cage, boosting your PC’s storage capability. Plus, two more 2.5” SSDs can be installed on the back of the motherboard tray for good measure! You’ve also got 420mm GPU clearance, with plenty of room left over for a 175mm tall CPU cooler and an assortment of fans and radiators.
Montech KING 95 PRO Midi-Tower, Tempered Glass, ARGB - Red
Montech KING 95 PRO Midi-Tower, Tempered Glass, ARGB – Red
CAS-MON-01485
★★★★★ (5)
£124.96 £ 114.95
-8.01%
(incl. VAT)
FREE SHIPPING
Pre order
ADD TO BASKET
Jonsbo TK-4 Wood Dual Chamber ATX Mid-Tower PC Case
The Jonbso TK-4 Mid-Tower PC Case has an air of sophistication about it. The roomy interior supports ATX, Micro-ATX, and Mini-ITX motherboards and offers space for numerous 2.5” and 3.5” drives. The dust filters are removable, making maintenance and cleaning a doddle, while back-connect motherboard support keeps cables tucked away and out of sight. Particularly useful, as this case also has a single curved tempered glass panel that delivers a glorious view of your hardware. If you’re a fan of fans, you can mount up to eleven of them, and the top and bottom panels can host radiators measuring up to 420mm. What’s more, the aluminium chassis features elegant wooden accents, lending a delicate touch to a robust build!
Jonsbo TK-4 Wood Dual Chamber ATX Mid-Tower Tempered Glass - Black
Jonsbo TK-4 Wood Dual Chamber ATX Mid-Tower Tempered Glass – Black
CAS-JON-06871
★★★★★ (5)
£199.99
(incl. VAT)
FREE SHIPPING
Pre order
ADD TO BASKET
HYTE Y70 Dual Chamber Mid-Tower ATX Case
HYTE is well-known for manufacturing exquisite PC cases. The HYTE Y70 Dual Chamber Mid-Tower ATX PC Case is certainly no exception. Air and water-cooling enthusiasts are catered to here, as there is support for up to ten fans, as well as large radiators at the top and side of the case! Of course, all this cooling potential is designed to support a PC build of epic proportions. This chassis is compatible with E-ATX, ATX, Micro-ATX, and Mini-ITX motherboards, and comes with multiple 2.5” and 3.5” drive bays. What’s more, a stylish PCIe 4.0 x 16 riser cable is included with the Y70, facilitating vertical mounting of powerful GPUs up to 422mm long. Plus, this case boasts a tool-less panel design to make installing and switching parts easier.
HYTE Y70 Dual Chamber Mid-Tower ATX Case - Snow White
HYTE Y70 Dual Chamber Mid-Tower ATX Case – Snow White
CAS-HYT-01823
★★★★★ (5)
£219.95 £ 179.95
-18.19%
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
Lian Li O11D EVO RGB Mid Tower PC Case
We all know that building a gaming PC can be quite the fiddly process. Lian Li has answered these problems with the Lian Li 011D EVO RGB. This mid-tower PC case boasts a unique, modular design. To make swapping out and installing parts easier, the frame is reversible and the motherboard tray is removable, ensuring nothing is in your way when making changes. The same is true of the fan brackets, too! Don’t like where the I/O is? Place it elsewhere on your case to make connecting your peripherals easier. On top of this astounding flexibility, this chassis is compatible with E-ATX, ATX, Micro-ATX, and Mini-ITX motherboards, and there’s clearance for GPUs up to 455.7mm long. Whatever PC build ambitions you have, this case can adapt to them!
Lian Li O11D EVO RGB Mid Tower Case - White
Lian Li O11D EVO RGB Mid Tower Case – White
CAS-LIA-01221
★★★★★ (5)
£149.99
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
Shop More PC Cases
If you still haven’t found what you’re looking for, don’t worry. The Overclockers UK range doesn’t end here, as we’re always stocking cube PC cases. Perhaps the chassis you’ve always dreamed about could be among them!
Learn More About PC Cases
Best PC Cases for the Office
Best PC Cases for Workstation PCs
Are You a Fan of Cube PC Cases?
Were you impressed by our picks? Do you use a cube PC case that’s a little flashier than the ones we listed? Keep us posted in the comments.
0 0 votes
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
