Best GPUs for Small Form Factor Cases
Looking for a graphics card to fit into your compact gaming PC? We’ve got a list of the best GPUs for small form factor (SFF) cases!
We’ve broken down some key details for you and, of course, got a tasty selection of graphics cards for you to peruse!
SFF GPUs
Small Form Factor, or SFF, products are much like their standard, full-sized counterparts just, you know, smaller. There are a variety of gaming components and hardware that come in SFF designs, including both PC cases and graphics cards.
But why do we need SFF products?
SFF PC cases are perfect for if you have limited space for a gaming PC, or even enjoy the challenge of building on a smaller platform. An SFF GPU is designed to harness the same powerful technology, but with a reduced footprint to make them an ideal fit for compact cases. Graphics cards seem to get bigger with every generation, so having the smaller alternatives means you can still opt for a powerful model. No compromising on performance to get a GPU that fits!
SSPUD Meshlicious - Black Lifestyle
We have scoured the Overclockers UK website for some small form factor GPUs that are just perfect for SFF PC cases and builds! We’ve picked out a selection of our favourites here for you, to inspire your next upgrade.
PowerColor Radeon RX 9060 XT Reaper 16GB GPU
Starting with the smallest GPU on the list, we have the PowerColor Radeon RX 9060 XT Reaper, measuring 200mm by 100mm by 39mm (LxWxH). Built on AMD RDNA 4 architecture with 16GB GDDR6 VRAM, this graphics card packs all the performance you need to enjoy smooth gaming from your small form factor PC. The RX 9060 XT is equipped with all the latest AMD innovations, harnessing AI-enhancements, FSR 4.0, and HYPR-RX to deliver crisp detail, realistic lighting, and high frame rates.
PowerColor Radeon RX 9060 XT Reaper 16GB GDDR6 PCI-Express Graphics Card
GRA-PWC-05257
£569.99 GBP
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
Zotac GeForce RTX 5070 Ti Solid SFF 16GB GPU
Select NVIDIA graphics cards are part of their dedicated SFF range. The Zotac GeForce RTX 5070 Ti Solid SFF 16GB GPU is the first of these on our list. Measuring 304.4mm by 155.8mm by 41.6mm (LxWxH), this slimline graphics card may take up less space in your PC case, but the Blackwell architecture still brings the performance you need! Utilising AI-accelerated Tensor cores and fourth-gen RT cores, this graphics card will bring your favourite games to life with real-time ray tracing, upscaled images, and fluid frame rates.
Zotac GeForce RTX 5070 Ti Solid SFF 16GB GDDR7 Graphics Card
GRA-ZTC-04898
£1199.99 GBP
(incl. VAT)
FREE SHIPPING
out of stock
ADD TO BASKET
Palit GeForce RTX 5070 Infinity 3 OC SFF 12GB GPU
The Palit GeForce RTX 5070 Infinity 3 OC SFF 12GB GPU is our next dedicated NVIDIA SFF graphics card. Coming in at 291.9mm by 116.6mm by 41.3mm (LxWxH), this mainstream GPU harnesses 16GB GDDR7 VRAM to keep all operations efficient with low latency. That leaves the 6144 CUDA cores and AI-enhancements free to optimise your gaming for life-like detail and immersive play on all your favourite titles.
Palit GeForce RTX 5070 Infinity 3 OC SFF 12GB GDDR7 PCI-Express Graphics Card
GRA-PAL-04406
£799.99 GBP
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
ASRock Intel ARC B570 Challenger 10GB OC GPU
Moving to Team Blue, we have the ASRock Intel ARC B570 Challenger 10GB OC GPU. This Battlemage graphics card measures in at 249mm by 132mm by 41mm (LxWxH) and brings the best of Intel Xe2 architecture to your gaming PC. Using AI-accelerated cores, 10GB GDDR6 VRAM, and clock speeds up to 2600Mhz, this GPU delivers smooth and detailed gaming with the like of Intel XeSS, XeFG, and XeLL optimising performance and display. Plus, the cutting-edge AV1 encoder makes this Intel ARC graphics card a great contender for both streaming and gaming PCs!
ASRock Intel ARC B570 Challenger 10GB OC GDDR6 PCI-Express Graphics Card
GRA-ASR-04236
£359.99 GBP
(incl. VAT)
FREE SHIPPING
out of stock
ADD TO BASKET
Gigabyte GeForce RTX 5080 Aero OC SFF 16GB GPU
Our final pick is the Gigabyte GeForce RTX 5080 Aero OC SFF 16GB GPU, bringing style and performance to the small form factor. This all-white graphics card measures 304mm by 126mm by 50mm (LxWxH) and even features RGB lighting on the Aero logo. It will certainly cut a fine figure in your all-white SFF build! More than just a pretty face, this graphics card wields Blackwell architecture and 10752 CUDA cores to deliver your games in stunning 4K resolutions. Plus, all the latest AI-enhancements on DLSS and RTX Neural Shaders mean you can experience immersive visuals like never before!
Gigabyte GeForce RTX 5080 Aero OC SFF 16GB GDDR7 PCI-Express Graphics Card
GRA-GIG-04128
£1589.99 GBP
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
Shop All Graphics Cards
Whether you’re looking for more power or a budget-friendly model, we have an extensive collection of GPUs from NVIDIA, AMD, and Intel. Click the button below to explore our complete range!
More of the Best GPUs
Best GPUs for Content Creation
Best GPUs for Etheria: Restart
Best GPUs for Ray Tracing
What GPU is in Your Build?
Are you rocking an SFF GPU? Let us know your spec in the comments below!
0 0 votes
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
