Best PC Cases
Looking to upgrade your PC case? We have the best PC cases of 2026 right here!
Best PC Cases of 2025
In this article, we’re taking a look at five of the best PC cases that have recently hit our shelves.
Exciting Innovation in PC Cases
A PC case is an essential part of your gaming PC. Without one, where would all the hardware go?! Far from the beige blocks they once were, PC towers have come a long way and now boast incredible aesthetics, innovative installation features, and all the support you need for premium hardware.
There are tempered glass panels to showcase your RGB lighting and components, expertly engineered interiors to optimise airflow, vertical GPU support – the list goes on and on. And we haven’t even got onto how they come in different sizes and colours!
Picking the right PC case is more than just selecting the chassis your hardware fits into. You have to consider acoustics, if you’re showcasing components, how you’re going to balance cooling. Thankfully, modern PC cases all come with a range of features to support all the various factors you consider important for your build.
PC Case Form Factors Explained - Everything You Need to Know!
Mid Tower vs Full Tower: Which PC Case is Best for a Gaming PC?
Best PC Cases for Water Cooling
Best PC Cases of 2026
Below is a selection of PC cases available from Overclockers UK. Each boasts innovative features and stunning aesthetics, making them must-haves for your next build.
HAVN BF 360 Flow Mid-Tower PC Case
While we very nearly picked the HAVN HS 420 DOOM Edition, the HAVN BF360 Flow is a PC case worthy of our attention. The sleek modern design, available in both black and white, will make it a fine addition to any gaming set-up, complete with a tempered glass panel to admire your hardware. It’s the innovative airflow coverage and included HAVN H18 180mm fans that really caught our eye. With aerodynamic funnelling and these powerful yet quiet fans, this PC case boasts impressive cooling out of the box, a must for keeping power-hungry components at optimal temperatures. Plus, there is support for E-ATX motherboards, 410mm long GPUs, and ATX power supplies which fully optimises compatibility with the current hardware market. Totally ticks all our boxes!
HAVN BF 360 Flow Premium Mid Tower Case - Black
HAVN BF 360 Flow Premium Mid Tower Case – Black
CAS-HVN-05948
★★★★★ (5)
£169.99
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
HAVN BF 360 Flow Premium Mid Tower Case - White
HAVN BF 360 Flow Premium Mid Tower Case – White
CAS-HVN-05949
★★★★★ (5)
£169.99
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
HYTE X50 Modern Mid-Tower PC Case
HYTE cases are always a break away from the mould, and we love them for it. The HTYE X50 Modern Series is their latest generation of innovations. All smooth curves, this PC case is expertly engineered to provide comprehensive component support with ample airflow, and it looks good doing it! Even the corners of the front mesh panel are rounded, a marvel of engineering. We particularly love the seamless panoramic tempered glass that curves from the top panel all the way down the side. Talk about an uninterrupted view! Plus, the rounded PSU canopy is the ultimate combination of form and function, facilitating hassle-free cable management and a stylish solution for PSU mounting. Better yet, this PC case is available in five colours, but we’ve picked out our favourite three.
HYTE X50 Modern Performance Mid-Tower ATX Case - PITCH BLACK
HYTE X50 Modern Performance Mid-Tower ATX Case – PITCH BLACK
CAS-HYT-06028
★★★★★ (5)
£149.99 £ 114.95
-23.36%
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
HYTE X50 Modern Performance Mid-Tower ATX Case - TARO MILK
HYTE X50 Modern Performance Mid-Tower ATX Case – TARO MILK
CAS-HYT-06031
★★★★★ (5)
£149.99 £ 123.95
-17.36%
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
HYTE X50 Modern Performance Mid-Tower ATX Case - WILD CHERRY
HYTE X50 Modern Performance Mid-Tower ATX Case – WILD CHERRY
CAS-HYT-06030
★★★★★ (5)
£149.99 £ 117.95
-21.36%
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
Phanteks Evolv X2 PC Case
The Phanteks Evolv X2 PC Cases are another showstopper, providing an unrestricted view of your PC interior thanks to the three tempered glass panels. Wrapping around the front and sides, you can view your prized hardware from near enough any angle. Everything about this build is for the showcase aesthetic. There is support for rear connector motherboards, recessed mounts and dedicated chambers for cooling hardware, and hidden compartments for select components. All you’re left with in the main chamber are centrepiece components and RGB lighting for peak aesthetics.
Phanteks Evolv Series X2 Case Tempered Glass Windows DRGB Brushed Black
CAS-PHK-03323
★★★★★ (5)
£130.99
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
Phanteks Evolv Series X2 Case Tempered Glass Windows DRGB Matte White
CAS-PHK-03324
★★★★★ (5)
£139.99
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
TRYX FLOVA F50 Mid-Tower PC Case
Our next pick is the TRYX FLOVA F50. This mid-tower chassis is optimised for outstanding cooling, without all the noise! Featuring fabric mesh panelling, the airflow in this case is peak. Pre-installed, there is a TRYX TCF cross flow fan which seriously boosts air intake and directly funnels airflow to heat sources. This fan has three performance speeds and you can adjust the blades to optimise flow for either air- or water-cooling set-ups. On top of all this, you’ve got back connect ATX motherboard support, up to 420mm GPU clearance, and mounts for up to eleven fans!
TRYX FLOVA F50 Mid Tower Case With Crossflow Fan - Black
TRYX FLOVA F50 Mid Tower Case With Crossflow Fan – Black
CAS-TRX-06528
★★★★★ (5)
£129.95
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
TRYX FLOVA F50 Mid Tower Case With Crossflow Fan - White
TRYX FLOVA F50 Mid Tower Case With Crossflow Fan – White
CAS-TRX-06529
★★★★★ (5)
£129.95
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
TRYX FLOVA F50 Mid Tower Case With Crossflow Fan - Pink
TRYX FLOVA F50 Mid Tower Case With Crossflow Fan – Pink
CAS-TRX-06530
★★★★★ (5)
£134.99
(incl. VAT)
FREE SHIPPING
in stock
ADD TO BASKET
Cooler Master Sneaker X Gaming Case
Our final pick is something a little bit different, a true showcase of engineering ingenuity. The Cooler Master Sneaker X is literally a shoe-shaped PC case and, frankly, we’re here for it. First exhibited in the Case Mod World Series 2020, this unique case can accommodate a Mini-ITX motherboard, 304mm long GPUs, and 120mm tall CPU coolers. That is pretty extensive compatibility with the current hardware market! For power, there is an ITX PSU integrated within the design, and there is even out-of-the-box cooling provided with the pre-installed 120mm fan. If you’re all about those bespoke experiences, then perhaps this will be the shoe that fits!
Overclockers UK’s Best of Hardware Guide
Best of Hardware
Looking to upgrade your gaming PC with the best of the best? Head on over to our hardware guide and see what goodies are just waiting to be added to your set-up!
Shop All PC Cases
Not feeling any of these cases? We have an extensive and ever-growing collection of PC cases on the Overclockers UK website. Browse our full selection and see if your next chassis is among them.
Explore More Great Hardware
Best Storage Drives
Best AIO Coolers of 2025
Best Gaming PCs of 2025
What PC Case do You Use?
Let us know in the comments what PC case houses your build, and the innovative features that made it a must-have!
5 1 vote
Article Rating
Subscribe
Notify of
guest
0 Comments
Oldest
Newest Most Voted
