Storage drives may not be the spiciest component in your gaming PC, but they can make or break your immersion. So, we’ve got the best storage drives of 2026 lined up for you!
It is 2026. If you are still rocking an HDD as your primary storage drive, then we need to have words. And they are, “Buy an SSD.” Ok, so HDDs do still belong in our gaming PCs, but they perform best as a secondary drive for holding all your media, files, and documents. For your games, you want a high-speed solid state drive, as the lack of moving parts ensures blindingly fast read and write speeds. The end result? Speedy loading times and no more waiting around! So, let’s get into the best storage drives of 2026!
Best Storage Drives of 2026
Storage drives are a vital part of your gaming PC. Without them, your digital game library wouldn’t have anywhere to go. You’d have nowhere to store and run your operating system. No apps, programs, files, music. See what I mean about vital?
There are two types of storage drives, hard disk drives (HDDs) and solid state drives (SSDs). For a long time, HDDs were the standard. They are relatively cheaper per byte, which is what makes them great for high-capacity storage in modern gaming PCs. SSDs, on the other hand, may be more expensive, but they are worth every penny. Utilising high-speed NVMe and PCIe connectivity paired with innovative NAND technology, an SSD will outpace an HDD every time. A middle ground would be SATA SSDs, which serve a similar purpose as traditional HDDs. They aren’t as fast as NVMe SSDs, but they still operate quicker than an HDD and don’t cost as much as their PCIe brethren.
All in all, many games now require an SSD, as an HDD simply cannot keep up. As such, the best storage drives of 2025 are all SSDs. Each model we’ve picked out has a 1TB capacity, but they are usually available in higher (or lower) capacities as you require.
WD Black SN8100 PCIe 5.0 2280 SSD with Heatsink
WD, or Western Digital, are a staple of the storage drive industry. The WD Black is a premium SSD, with the latest SN8100 model featuring PCIe 5.0 technology and a dedicated heatsink. This SSD boasts read and write speeds of 14,900MB/s and 11,000MB/s, respectively, for ultra-fast performance whether you’re gaming, streaming, or creating content. Powered by TLC 3D CBA NAND technology, the WD Black SN8100 is incredibly reliable, boasting an average lifespan of 600TBW (Terabytes Written).
Kingston FURY Renegade G5 PCIe 2280 SSD
The Kingston FURY Renegade G5 SSD features a Silicon Motion SM2508 controller and a low-power DDR4 DRAM cache. This allows for better thermal management and less power consumption, making the FURY Renegade G5 a fine addition to your gaming PC. Plus, the 14,200MB/s read and 11,000MB/s write speeds are nothing to be sniffed at! The twelve-layer PCB provides enhanced signal quality and data integrity, enabling consistent performance even under heavy work loads. Enjoy unmatched efficiency in both work and play!
Corsair Force MP600 CORE R2 Mini PCIe 4.0 2230 SSD
The Corsair Force MP600 CORE R2 Mini is a little different to the rest of the SSDs on this list. Instead of the 2280 form factor, this SSD utilises the 2230 size, which is much shorter. This makes it suitable for upgrading the storage on your handheld consoles and tablets. With this SSD, you can bring increased capacities and read/write speeds of 5,000MB/s and 3,800MB/s to your PCIe 4.0-compatible devices!
Samsung 9100 Pro PCIe 5.0 2280 SSD with Heatsink
The Samsung 9100 Pro harnesses PCIe 5.0 technology to deliver read and write speeds of 14,700MB/s and 13,300MB/s, respectively. On top of this, you can use the Samsung Magician suite of optimisation tools to ensure this SSD is performing its best within your gaming PC. The included heatsink will draw heat away from vital components, while the advanced 5nm controller power architecture has improved energy efficiency by up to 49%. This SSD is ready to handle even the most demanding workloads!
Crucial P510 PCIe 5.0 2280 SSD
Our final pick is the Crucial P510 SSD. Once again, this solid state drive uses PCIe 5.0 technology to deliver impressive read and write speeds of 11,000MB/s and 9,500MB/s, respectively. You can game and work with reduced loading times and enjoy the enhanced system responsiveness that comes with it. Featuring a single-sided design, this SSD is great for upgrading gaming laptops, especially as the power-efficient architecture consumes up to 25% less power for longer battery life!
Best of Hardware
Looking to upgrade your gaming PC with the best of the best? Head on over to our hardware guide and see what goodies are just waiting to be added to your set-up!
More Storage Drives
Of course, even in 2025 there is space in our gaming PCs and hearts for HDDs. At Overclockers UK, we have an impressive collection of hard drives, both internal and external, that boast incredible capacities and optimised data transfer. Plus, there are even more SSDs to explore, too, should none of the above fit your spec or budget. Check out our full selection with just the click of a button!
Learn More About Storage Drives
What Storage Drives Are You Rocking in 2026?
Let us know in the comments below what storage solution you’re rocking!
