Our Indie Showcase is continuing through 2025! Each month, we’ll pick a recently released independently developed game to shine the spotlight on. Whether they’ve launched to rave reviews or have been a slow burn that’s captured the imagination, these games deserve their day in the sun! For September, we’re looking at the cosy management sim… Tiny Bookshop!
What is Tiny Bookshop?
Tiny Bookshop is a casual, relaxing game developed by neoludic games and published by Skystone Games and 2P Games. As you would expect, your task is to run, well, a tiny bookshop from a wooden caravan.
Set in the charming Bookstonbury-by-the-Sea, learn the ins and outs of the town, discovering its history and the locals. You’ll need to stock the books they like to read, after all! The townsfolk are a friendly bunch, and you can even make book recommendations to help them find their new favourite read.
Of course, a vital part of cosy management games is the customising. Your tiny bookshop needs to give off the right vibes! You can decorate your shop with items you collect around town and create the perfect aesthetic. The atmosphere will have an effect on your customers and may even unlock new mechanics to harness.
Tiny Bookshop Reception
Since its launch on August 7th 2025, Tiny Bookshop has amassed Overwhelmingly Positive player reviews on Steam (correct at the time of writing). It seems everyone can’t get enough of these cosy vibes!
Tiny Bookshop Official Specifications
What does it take to run a second-hand book store from your gaming PC? Here are the official specifications for Tiny Bookshop:
| Component | Minimum Specs | Recommended Specs |
| Operating System | Windows 7* 64-bit | Windows 10 64-bit |
| Processor | Intel Core i5-7360U | AMD Ryzen 5600G |
| Memory | 8GB RAM | 8GB RAM |
| Graphics | Intel UHD 630 | NVIDIA GTX 1060 |
| DirectX | Version 11 | |
| Storage | 2GB available space | 3GB available space |
Best PCs to Play Tiny Bookshop
With casual specification requirements, your gaming PC is already likely able to run Tiny Bookshop. But if you’re after an upgrade or two to create that perfect book store aesthetic, then you’re in luck! Overclockers UK has an extensive range of gaming PCs and laptops that are perfect for living out your best cosy life! We’ve picked out a few here, or you can click the buttons below to explore fully.
OcUK Gaming Mach 1.1 Pre-Built PC
- Pre-built gaming PC – engineered for 1080p gameplay!
- AMD Ryzen 5 5600 CPU
- NVIDIA GeForce RTX 5060 GPU
- 16GB RAM and NVMe SSD storage
- Covered by our three years parts and labour warranty
MSI Cyborg 15 Gaming Laptop
- 15.6” FHD 144Hz gaming laptop
- Intel Core 7 240H CPU
- 16GB DDR5 RAM and 512GB NVMe SSD
- DTS Audio technology
OcUK Gaming Kite Custom PC
- Configurable gaming PC – adjust the base spec to suit your needs!
- Select an AMD Ryzen 7000 or 8000 Series CPU
- Your choice of AMD Radeon RX 9060 XT GPUs
- Up to 64GB DDR5 RAM
- Choose up to three storage drives
