With USB Type-C becoming increasingly popular, is it finally time to say goodbye to our old trusty USB Type-A cables?
In this blog post, we’re taking a deep dive into USB Type-A, covering what this standard is, if it’s still useful, how Type-A compares to USB Type-C, and all the pros and cons of this connector.
What is USB Type-A?
USB Type A is the original standard, first introduced alongside USB in the 1990s, featuring a rectangular-shaped USB that is used to connect a wide range of devices. This includes keyboards, mice, external drives, and more.
A USB Type-A cable is backwards compatible with all generations, from 1.0 to 3.2.
Is USB Type-A Dead?
USB Type-A isn’t completely dead, but this standard is being phased out slowly, with more manufacturers switching to USB Type-C.
Today, USB Type-C is considered the superior standard due to its user-friendly reversible design, faster data transfer rates, high power delivery, and more. Since USB Type-C is capable of transferring data and powering a device simultaneously, it’s quickly become the standard supported by a wide range of devices, including mobile phones, tablets, monitors, and more.
However, while USB Type-C is becoming increasingly popular, USB Type-A is still widely used.
USB Type-A is great for its backwards compatibility, supporting every type of USB standard. This means you can use this cable on old consoles and modern-day devices. All without requiring any additional adapters. As a result, peripherals such as keyboards, mice, and even car chargers are still being released with USB Type-A.
What’s more, while these cables feature a simplified non-reversible design, this does make USB Type-A cheaper for manufacturers to produce.
USB Type-A – The Pros and Cons
Pros
- Established standard – USB Type-A is widespread and used to connect/power a wide range of devices. It remains as reliable for maintaining any old hardware as it was when it was first released.
- Universal compatibility – USB Type-A is the most widely used connector, found on numerous popular devices and peripherals.
- Supports all USB standards – Since it’s backwards compatible with other generations of USB, you can use a USB Type-A with practically anything.
Cons
- Slower data speeds – USB Type-A is notably slower than USB Type-C, especially when you are working with files that have a large capacity.
- Non-reversible design – The iconic rectangular design of a USB Type-A cable can only be inserted in one orientation. USB Type-C, on the other hand, is reversible, meaning you can plug it into any port in either orientation.
- Limited power delivery – USB Type-A cables typically deliver less power than their modern-day counterparts, making them unsuitable for charging demanding devices.
- Large physical size – The bulkier size of the USB Type-A connector means it is not well suited for more compact devices.
Can I Still Use USB Type-A?
Yes – USB Type-A is still widely used in 2025.
Devices such as keyboards, laptops, and gaming mice are still being released with USB Type-A connectivity. Legacy hardware, including older consoles, also features USB Type-A, meaning you can connect your controller to your laptop and your old PlayStation.
What’s more, while USB Type-C does notably improve upon features such as data transfer rates and power delivery, Type-A is still just as dependable. If all you’re looking for is basic yet reliable connectivity and charging, USB Type-A is a fantastic option.
Is There an Alternative to USB Type-A?
If you’re looking to put a little more oomph into your devices, then USB Type-C is the modern alternative for you.
This type of connector is perfect for tasks like charging smartphones, as you want fast, rapid charging when on-the-go and quick transfer rates when backing up precious files. Not to mention, the reversible design removes any fiddling or unnecessary hassle, making sure you’ve got the USB port plugged in the right way around.
Still on the hunt for the right USB cable for your set-up? You can read more about all the different types of USB and connectors in our dedicated blog post.
In Need of an Extra USB Cable?
In need of a USB cable to connect even more devices to your set-up? At Overclockers UK, we stock an extensive range of USB cables, adapters, and hubs, all designed to help streamline your set-up.
You can explore our full collection with the click of a button.
Expand Your Connectivity
Do You Still Use USB Type-A?
Do you still use USB Type-A? Let us know in the comments below!
