Additional screen real estate is always useful. As such, the Lian Li 8.8″ Universal Screen is the perfect choice if you want to add a versatile secondary screen to your gaming set-up.
Versatile Screen
The Lian Li 8.8″ Universal Screen will enhance your PC set-up. The 1920 x 480 IPS LCD panel can be used to display anything from real-time system information to personalised images or videos. Any image shown on this screen will be vibrant and crisp, thanks to the 60Hz refresh rate and 500 nits brightness.
Connecting the Lian Li 8.8″ Universal Screen is a simple task. It just requires a single USB cable and features plug-and-play functionality. That’s right, no GPU output required!
Controlling what’s on-screen is easy, as the Lian Li 8.8″ Universal Screen is fully compatible with Lian Li L-Connect 3 software. Using this software, you can customise the screen with a range of preset themes and modules to show real time system information. This includes CPU temps, GPU clock speeds, and memory usage. Alternatively, you can use the monitor to personalise your set-up with images, GIFs, and even videos.
Plus, L-Connect 3 can also control the ARGB strip that frames the screen. Supporting a wide range of colours and effects, you can synchronise this lighting with the rest of your computer’s RGB hardware to create a unique aesthetic.
Flexible Mounting
Installing the Lian Li 8.8″ Universal Screen is just as simple, thanks to its flexible mounting system.
Your first option is to use the included mounting bracket. Simply attach this to the screen, and it can be mounted to a fan bracket or PC panel using standard fan mounting screws. Once installed, the bracket offers a fantastic range of adjustability, with both horizontal and vertical toothed sliding rails. The screen can also be rotated and tilted, allowing you to angle your screen for the perfect display.
The alternative option is to eschew the bracket entirely and mount the screen directly to a flat surface using self-adhesive. If you do choose this option, you’ll need to ensure the surface has enough space to accommodate the screen, which measures 237mm x 73mm x 13mm (LxDxH).
A Visual Feast
Is this screen the perfect upgrade for your gaming set-up? Let us know in the comment section below how you plan on using it, then head on over to Overclockers UK today and get your order in.
  • 8.8″ 1920×480 display
  • 60Hz referesh rate
  • 500 nits peak brightness
  • USB connectivity
  • Vibrant RGB lighting
Newsletter phone image
Stay Up to Date!
Keep your finger on the pulse for all things tech, by signing up to our Newsletter!
0 0 votes
Article Rating
Subscribe
Notify of
guest
4 Comments
Oldest
Newest Most Voted
kai
kai
1 year ago
what date will this ship
Emily Haylock
Editor
1 year ago
Reply to  kai
Stock should hopefully arrive towards the end of October.
Eric
Eric
10 months ago
got 2 of the white ones. love them.
Emily Haylock
Editor
10 months ago
Reply to  Eric
