1080 ti GPU Repair/Fix/Help :)
23 Oct 2020
Hi guys and gals
I am kinda new to this so I thought I'd ask opinions first, I recently acquired a nivida gpu (I assume palit by the power layout) however I have no idea what the card is
Looking at the ram slots I am guessing a 1080 11gb however I am not sure on where to start the repair (if possible)
Any help would be greatly appreciated :)
Chip Number (1745a1 pgfu00 002)
Images
https://1drv.ms/u/s!ApfImBXZnhHzhkLKIm0K0k5KFC1v?e=xSwoPo
OP
23 Oct 2020
when its plugged in, the fans spin up but there isnt any output.
there are a few parts missing including inductors (LR22 x4), mosfets (SIC632 x3) and caps (110uf x3) which is why i can under stand that there isnt any output
however the main issue i have is that i cannot find similar pcb to compare to, the closest i have found is a palit jetstream 11gb however the gddr5 slot (m11) is diffrent
29 Oct 2002
I agree with the others, it would be impossible to know exactly what was removed and why, it's likely been cannabalized for parts to get one card working from two. Bin it, or sell it for parts.
3 Jul 2012
If you don't have a strong PCB background and know what your doing, you may be wasting your time, even with experience the core itself may be dead.
