1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
£150 for an AGP card
Discussion in 'Graphics Cards' started by Deep, 16 May 2006.
  1. Deep
    spend away!
    as in title, what card should i get? as long as its good thats all that matters
    ive got a p4 2.8ghz, 1gb ram below that preferable. also how much will i get for 9600 128mb, we can factor the cost in of that aswell. say if i got £60 i then have £210 to spend
  2. Behemoth
    Mobster
    If you've got £150 to spend on AGP then your best bet is going to be the 6800 GS, pretty decent card for that money. Even if you had £210 you'll be hard pressed to find anything on AGP.
    I think there's or have seen a Radeon X800 GTO 2 for AGP, but that doesn't have Shader Model 3 support like the 6800 GS does.
    Unless of course you can stretch your budget upto a 7800 Gaidward bliss card then that should sort you right out :)
  3. danceMB
    Wise Guy
    Unless your willing to go second hand. If so I could have something that you might like, in the 6800 Ultra range
  4. semi-pro waster
    Man of Honour
    Brand new a 6800gs is probably the best bet for the money. Secondhand anything from the X800XT/X850XT or 6800gt/6800ultra selection.
    Your old 9600pro isn't likely to fetch anywhere near £60 I'm afraid, more like £20-30 if you are lucky, you can get 9700/9800pro cards for (a lot) less than £50 regularly now.
  5. fenderbass86
    Wise Guy
    That's right, I sold my 9600XT last autumn for £30, I put it in the ad for £35. So you might just about get £30 for it.
