Bit of advice, don't use Overclocker to clock Use ATITool.
That way, the memory timings stay tight and you get better scores for the clocks
Duke said:Links in OP don't work?
You need to tick one result per program as 'published'The_One said:The last ORB link works, the other 2005 links wont work because it only lets you have one result active at a time?
Goksly said:whats ** core voltage / max temp with that overclock?
Bennah said:Nice card you got there mate... Good luck for 11K in 05, Im sure you can get there with some british cold air
What speed is your ram at btw? 280 1:1?
A random name got 11,032 in 05
Sandy 1MB @ 273x11 3005MHz and the card @ 749 / 922.
Seems that you can possibly push the card a little more to get to the 11K mark...
welshtom said:01 seems very low to me
