Hi there guys im just about to orer a new case for my build and i realised a problem. the case i want to order(Coolermaster Haf X) has 2 front usb 3.0 connections but my motherboard (Gigabyte GA-EX58-UD5 Intel X58) does not have any. i have been looking around for some kind of solution to this but i have not come across any. can anyone recommend me anything? would this work? http://overclockers.co.uk/showproduct.php?prodid=CB-072-AK
The HAFX has a pair of USB3.0 cables that usually pass through the case, out the back and into the rear USB3.0 ports on a motherboard with rear USB ports. The only way you can add USB3.0 support to your board is with a controller card, http://www.overclockers.co.uk/showproduct.php?prodid=HD-019-AK&groupid=701&catid=49&subcat=423 Or the case includes a cable to convert to internal USB to fit onto a motherboard, http://www.guru3d.com/article/cooler-master-haf-x-review/8
OcUK 4 Port USB3.0 External Hub http://www.overclockers.co.uk/showproduct.php?prodid=CC-000-OP&tool=3 edit, your mobo has no usb 3, doh.
