Enfield said:
Yeah it's incorrect.
It's been proved by a certain member on these boards that it can do under 10s. Also it shares the same engine as the Citroen ZX which according to Parkers does 0-60 in 10.2s I think it is?
it also shares the same chassis/brakes/suspension
you know where i am going.
as said already main thing is suspension and electrics, if your handy wityh a spanner the suspension is not a problem, P bushes are common and cost about £8 each, wishbones too , and also Droplinks go too these are about £15 each side, on the rear you might get a knocking that will be your torsion bar mounts (again no more than £40) they are reasonably common to go (well i mean it is likely to go one time in the cars life) but not as often as front suspension.
the door wiring looms are a pain in these and can cause all sorts of electrical faults bad design means the wires break in the doors. Alarms dont often work due to crappy pug alarm siren.
Power steering ram is often a common leak too costs about £90 from gsf and is an easy enough job if you can get under the car.
As with anycar make sure the cambelt has been changed on schedule, i think its 60k for the diesel? not sure on this though worth checking up on as you dont want it to snap
Airbag light may come on too due to wiring under seat being dodgy (common on PSA cars) takes a 10 min fix reconect and secure the conection.
the Xud9 engine will go on for ever as long as you give it 6-7k oil changes, the gearbox is not quite as strong but is pretty good and often a lot of box problems are just due to crap oil, so a quick change fixes this and makles shifts much smoother.
