Alright guys and girls,
Ive got a 360 premium and connect it up to my dell fp2001 via a 3rd part vga cable. Sometimes the screen takes on a yellow hue to it and all colours go. If I unplug and then plug in the vga connector to the 360 it solves this for a while. Has anyone else had this?
Is it likely to be a prob with the xbox or the vga cable. Unplugging the end that goes into the monitor doesnt fix it, it has to be replugged at the 360 end. Just want to know because if its a problem with the 360 then I want to get it exchanged under warrenty while I have it.
ta
ta
