1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
360 questions
Discussion in 'Console Games & Hardware' started by AHarvey, 9 Jun 2010.
  1. AHarvey
    Capodecina
    Hi all,
    Couple of 360 questions:
    1) I have an elite + cables however i've been given a couple of older core packages for repair but the power cable doesn't fit. It's slightly different in the middle. They also have slightly different power outputs. Can the newer one have the small piece of plastic removed to work or am I going to have to buy a new power cable?
    2) Any site recommendations for xbox repairs and moddifying? I currently have 6 xbox's downstairs with various problems :(
  2. mole90
    Gangster
    With each new generation of the 360 motherboard, they had a different power supply (lower wattage each time). Each gen of the PSU can only power its own gen console or newer ones - e.g. you can't use the newest Jasper one to power older consoles but you are supposed to be able to use an original (release day) one to power any 360.
    http://img218.imageshack.us/i/360powersupplies.png/
  3. orderoftheflame
    Capodecina
    This is correct afaik. :)
  4. Vonhelmet
    Caporegime
    If the old ones can be used on new ones, then they should be a dime a dozen on ebay, or you could try cex.
  5. AHarvey
    Capodecina
    ok, thanks for the info. Ebay was my next port of call, especially with the fact 360 failures are common and PSU's aren't :)
