3DMark DirectX Raytracing Feature Test & Port Royal Bench Thread.
19 Oct 2018
OP, please update my score, I had a HUGE score improvement with Win10 1903 May update on the AMD Ryzen Threadripper CPU, also I deleted the old score from Futuremark's database.
https://www.3dmark.com/pr/103207
Score 9709 / Graphics Score 9709
2080Ti RTX 2115/4030
1920x @4.025Ghz
430.86
Cheers
28 Oct 2005
Scotland
Nice score - is that under water?
It's an Asus Strix OC 2080 Ti I've got so just the standard cooler on that one. Just used the OC Scanner tool and popped 500 onto the Memory at this point.
Need to play about with he clocks more and see what else I can get out of it, impressed so far. Replaced a FE 2080 standard.
My 2700x is sitting at a constant 4.025Ghz at the moment under an H115i, will probably look to push that a bit further for a consistent clock but happy with the temps etc at the moment.
1 Apr 2014
Aberdeen
Hey @Kaapstad , can you make an additional note on my 2080 Ti entry that the GPU was in a x8 slot? Because that's an additional slow-down. Thanks.
Now I've done a reinstall, changing the clocks works and I've put it in a x16 slot, so it will be instructive to measure the change.
