1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
5.25" hot swap 3.5" hdd bay advice required
Discussion in 'Optical Storage & Writing' started by pete_agreatguy, 18 Aug 2017.
  1. pete_agreatguy
    Gangster
    Hi all,
    I've recently got myself an Orico 3.5" hot swap drive bay for use with backups.
    My query is simple. It comes with a power switch at the front. In terms of, after finishing a backup cycle, is it best to, in your opinion:
    a) Just switch the drive off using the power switch on the hot swap bay and remove the drive
    ... or ...
    b) Go into Disk Management and make the drive offline, press the power button and then remove the drive
    ... or ...
    c) OTHER ... please state in a reply !
    Just want to make sure I'm shutting these drives down the proper way just as if you were shutting down windows.
    Thank you in advanced :)
  2. ANDARIAL
    So the heads cannot crash onto the platter is my thinking
  3. pete_agreatguy
    Gangster
    Hi Andarial,
    I've gone and found a solution but still require advice.
    I've downloaded HotSwap! software (link).
    It seems to work well with my hot swap drive. However, should I still put the drive into offline mode within Disk Management to be safe?
    PS: I never had the option to remove safely before which puzzled me!
  4. ANDARIAL
    According to your link it does the same as Disk Management
    Should be more user friendly
    Maybe try it a few times with a hdd loaded with copied data to test?
  5. ZXSpectrum
    Sgarrista
    If your motherboard supports hotswap on your sata ports it should be fine anyway.
  6. pete_agreatguy
    Gangster
    Works perfectly fine. I only load up the software mentioned above when using the hot swap drive bay though. Everything else is picked up by Windows 7 Ultimate x64 without issues.
