owns it
Yeah that's sort of what I was getting at. The 5850 is a much faster card for sure, but the GTX 260 handles most things very well. So for example going from 100 to 130FPS is not going to be very noticeable IMO.
What we need are some games that use new engines
I am actually considering picking up a 260 and using it til the refreshes come out or there are more next-gen choices.
Also you could always throw another 260 in there and go SLI.....
Not worth it... overclock the 260GTX or Upgrade to a 5870... only way its worth getting a 5850 is if you can guarantee around 30-35% overclock on it... otherwise framerates are mostly still in the same ballpark - even tho the 5850 is faster.
Depends how you look at it... from an enthusiasts pov... and taking overall scores into account rather than the handful of games the 5850 is outright better...
A decently OC'd 260GTX can manage say 42fps and a mildly OC'd 5850 49fps... granted stock for stock that would prolly be more like 36fps v 45fps.
I'll probably stick with the 260 then. Last time i changed GFX i was dissapointed ( went from 8800GTX SLI to a single GTX280 ) so dont want to do that again.
....come on....where do you pull these figures out of?!? a 260 is not in the same league as a 5850...
http://www.techpowerup.com/reviews/HIS/HD_5850/30.html
NV should employ you to be their spin doctor.
22% difference over all resolutions... baring in mind that most 260GTX will overclock 20-25%... even poor ones will do 15-20% OC... I think that puts it in the same ballpark unless you can get a good OC on the 5850.
what? 15% is only 833MHz. THey all do more than that easily on stock voltage.....come on.
I can run all my games at 1920 x 1200 with 8xaa and they all run faster than ,my gtx260 did at 2xaa
