1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Competitor rules
    Dismiss Notice
5850 and 3 screens?
Discussion in 'Graphics Cards' started by shane242, 17 Apr 2010.
  1. shane242
    I currently have a 5850 running 2 22" screens, only issue is i want a bigger one between. 22" just isnt big enougth to game for me now.
    i have been looking at the display port on the card, are there any problems with useing the display port with adapter to run an additinal screen? (pehaps one of my 22"s) then run a 27 between them? with a dvi.
    I would get another card. but i dont have crossfire support on my board, if i get anew i may aswel get a new sockett, i5 blah blah. £1,200 just isnt an option right now.
    Thanks in advance
  2. reiyushin
    Eyefinity port? You mean display port? You can happily run 3 monitors on a 5850 :)
  3. jkulas
    Gangster
    I don't think you can do it with different sized screens, at the moment I have a 24" widescreen and a 19" 4:3 to the right. I would ideally like to put another 19" to the left so the 19s act as periphery.
    I think there are still problems with eyefinity and crossfire too. If anyone has any insight I'd also be interested in doing this.
  4. shane242
    oops, thanks. guess thats what happens when i type a topic while on the phone lol.
    i heard there is issues with the desplay adapters and screen flicker and screen colour being crap. anyone running 3 screens on one?
  5. reiyushin
    I'm running 3 screens on my 5870, the screen flicker is countered by having an active displayport adaptor :)
    If you just plan to use them as separate monitors then any 3 screens can be used, if you plan on using them as 1 big screen for games then they must all support the same res or the minimum supported wil be used.
  6. wilywez
