1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Competitor rules
    Dismiss Notice
5870 fan spun at 100% rebooted and cpu overclock failed message? help!
Discussion in 'Graphics Cards' started by doggles, 5 Mar 2010.
  1. doggles
    Hitman
    Hi
    I just recived a 5870. it's worked fine till about 5mins ago. Turned my pc on no signal to monitors, restarted it then the cards fan spun at what sounded like the max speed and still no signal.
    rebooted again and recived a message saying that my overclock had failed.
    the pc has booted fine now but i wonder has anyone else had this happen? if so do ya know why???
  2. RJC
    Don
    It has happened to me once before on various gpus, re-do your overclock and double check for stability.
  3. UKDTweak
    I had a similar fault a while ago, my Q6600 was clocked to 3600, with 2 x 8800 GTS (512 & 320).
    Came home one day and booted up fine, then shutdown to add an SSD... upon powering back up, no display... then after another reboot and no display, I removed the 320GTS and booted up, bios reported bad OC.... I restore the bios default and CPU settings and was then able to get back into windows....
    I could not get my old 3600 OC working again, so left it at 3000 for a month or two, then one day decided to try adding the old 320 GTS back in and it botted and ran fine for a few more weeks, I have since upped the OC to 3200 and so far working well ???
    To be honest, no idea what caused it, but I think it was my Hyper Type R PSU, can't confirm this, but I have now replaced this with a new 700 PSU and replaced both GPU's witih a 5850, so might try my old 3600 settings again..
    Do you have another PSU to test, also, try memtest in case one of your ram chips has failed.
  4. doggles
    Hitman
    cheers the processor overclock has been fine for months though.
  5. doggles
    Hitman
    cheers, no dont have a diff psu, it's a 700w ocz modextream so should have sufficent power - will run memtest tho
