6800LE - Multiple Monitor - Simple Question
25 Jul 2004
Carmarthenshire, SW Wales.
I'm running a nVidia 6800LE with an OCUK 17 Inch TFT. I've got a CRT here, what happens if I use a DVI > VGA connector for the TFT, and plug the CRT into the usual VGA socket?
Can it do multiple monitor with the one AGP Card?
Cheers!
6 Dec 2005
Cambridge, UK.
Yes, yes it can. I had my 6600GT (1 DVI and 1 VGA connector) with 2 TFT's plugged in to it. Using a 7900GS with dual DVI connectors to connect them now :) - both AGP cards ;)
