80mm case fan for SS LC-03
17 Dec 2005
Hi,
I am going to fit an 80mm fan in the spare blow hole @ the bottom of my HTPC case (silverstone LC-03) under HDD's. What 80mm fan would give best noise/performance ratio?
Want to keep noise levels down as the whole thing will be virtually passive cooled. Just want a fan to take the heat from the drives straight out of the case instead of blowing across the whole system.
Cheers
David
9 Nov 2003
Leeds
You will need to have the fan running at 5v/7v to get the best noise levels out of it.
The SilenX fans are good at 80mm, as are the zalmans (the zalman fans come with a volt modding adapter so its nice and easy)
9 Nov 2003
Leeds
No worries, I love the packaging on the Zalman fans, in the cardboard boxes.
Just think its how it should be done, none of the plastic to cut yourself on!
