A slightly complicated spec me up
27 Nov 2009
Maidstone, Kent
400W will definately be fine for now, even the i7 systems with 5850s only come in at around 350W max (not overclocked), and both the CPU and GPU will use more power than you will. Also, the PSU you have is pretty good, so will be up to spec anyways.
If you are particularly worried about it, wait until OCUK have some of the OCZ PSUs on offer again (or a Corsair, Antec et al), and pick up a 500W+ unit for cheap(ish).
OP
19 Dec 2004
Oh right, I'm only a tad weary due to my friend saying that 30A on a single rail PSU is a bit dodgy, which is why I'm asking for confirmation about the Corsair. If you guys think it will be fine then I'll go for it.
11 Apr 2008
Sheffield
Will be alright unless you decide to go for CF 5850 or 5970 : ).
Or Fermi which will probably require around 1.5 KW but probably at their 2999.99GBP price they will ship them with free 3KW PSUs ;).
OP
19 Dec 2004
I was thinking of getting the 5850, though the Fermi is out of my price range. :p
Thanks for the help guys, it seems the spec me up is complete. Time to purchase me thinks!
