ADSL Wireless Routers and Bridges
18 Oct 2002
Stone, Staffordshire
After years of NTL service I've moved to a BT only house.
I've ordered the Nildram 2mb service but the hardware that they have on offer is overpriced!
I've got a wireless laptop and a wireless card in my main PC so I'm looking for an ADSL wireless router.
Also I'd like to get a wireless bridge / gaming adaptor as I need to get my Xbox hooked up and my TiVo. Does a device exist with 2 or more ports to save me swapping cales?
I also didn't order Nildrams microfilters as I wasn't sure if the router and bridge would come with them, only have 2 phone points so would just be the 2 filters anyway. Is a filter a filter or are there any recommendations here?
9 Jan 2003
Cornwall
if you just need ethernet ports for your TIVO and XBox then you can plug that into any wireless router with a standard ethernet cable.
if your looking for actual bridges (so you can connect them to a wireless hub, ie over the wireless) then I'd go for somthing from linksys or netgear, you can mix and match the bridge/hub but don't forget you may been to configure the bridge using the cable connection.
if it was me I'd slap a 4 port switch/hub onto the bridge to save having to swap the cables, I dunno if a normal wireless AP would work the same tho.
OP
18 Oct 2002
Thanks for the reply, it's going to have to be a bridge as I can't run the cable to the router.
Are there any 4 port hubs that don't require power?
9 Jan 2003
Cornwall
no, they will all require power one way or another, as will any bridge.
I've used the Netgear 5 x 10/100 Compact Switch FS105, nice little box, works fine with the rest of my 10/100 kit too, but as I said, it WILL require power (bloody big plug block jobbie) as will the bridge.
9 Jan 2003
Cornwall
wonder_lander said:
After some research it appears that a wireless print server like the Netgear WGPS606 would acheive what I want. Does anyone have any experience or comments?
looks about right, odd that they would call it a Print Server rather than what it realy is, a Wireless Bridge WITH print server
