1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Competitor rules
    Dismiss Notice
air cooled opty owners
Discussion in 'CPUs' started by gazozborne, 6 Jul 2006.
  1. gazozborne
    Gangster
    Just wondering what temps yours are running at during these summer months? (or rather, when its quite warm :p )
    Weird question i know but im just checking if mine is too hot, its 41c at the moment (baring in mind my windows broken, just a fan in here). Used to be 32c when i first bought it, i've re applied Arctic Silver again today but during games it hits 51c, its got an AC freezer pro on it - is this a normal temp?
  2. red11
    Sgarrista
    That's fine, mine idle at 39/40c and the highest I've seen them go up to was 58c but that was with my case closed. With the side off and a fan blowing into it, temps don't go above 54c. This is with a Akasa Evo120.
  3. Stan_Lite
    Man of Honour
    Load temps on my 170 are between 50 and 54 depending on ambient temp, running [email protected] 24/7 - perfectly acceptable IMO.
    Stan :)
  4. Viral
    Gangster
    Mine sits around 41c at idle and 54c-56c when running games like Oblivion etc. I have mine clocked to 2.6Ghz in a Antec Sonata 2 case, so not the best cooling but its nice and quiet.
  5. cyclopopcicle
    Wise Guy
    mine is sitting at 36 with a case temp of 31
    room temp st the moment (7:46am) is 25
    akasa eve 120
    load temps are at around 46 gaming
    opti 146 sitting at 2.6
  6. Amps
    Mobster
    Mine sits at 36-38 when idleing and hits about 55C when under full load.
    Thats at 2.95Ghz with 1.57V through its ass.
    Running alkmost silently 1 silent 7 volted 120mm and 1 intake , 1 exhaust at 5v.
    Thats in an antec sonata and using an ThermalRight SI-120 and the computers ina cupboard.
  7. 22BUK
    PermaBanned
    My Opty 148 runs at 2.9GHz in a shuttle. Load temps hit 60deg. 3GHz hits 65deg and requires more than stock volts so I only run at this speed for benching.
  8. Neo4
    Wise Guy
    Running at 51c 2.7ghz on a Opty165 that's whilst running 2xsp2004 small ftt.
    Thermaltake Kandalf 2x 120mm intake 2x 120mm exhaust XP120
    Cooler.
    2.7ghz it idles at 33c.BF2 it climbs to 47c.
  9. Murzo
    Hitman
    My opty @2.7 sits at:
    29 degrees idle
    38-40 load
  10. FrankJH
    Capodecina
    whats the best way of measuring temp?
    I have never really looked into this even though I should
    I currently have an Opty 170 with a freezer pro only doing 2.5Ghz on an Abit crossfire board until I can change my psu
  11. n3x
    Hitman
    my opty reached 59 on the hottest day so far this year, had no problems tho :)
  12. gazozborne
    Gangster
    Ah doesn't seem as bad as i thought then :p - Was a bit worried as people used to mention 50c+ being too high for an opteron, forgot to mention mines @ 2.5 but going by everyones temps it looks to be normal then.
    Cheers people :)
  13. james.miller
    Capodecina
    opteron 148 @ 3ghz/1.55v - 53c load. cooled by a scythe ninja with the stock fan
  14. stigggeh
    Mobster
    i have a dodgy sensor on my shuttle it hits 45c [email protected] with cpu fans on 60% BUT i am sure is more like 55c
  15. Sparky-F1
    Sgarrista
    Running my 165 at 2.7ghz and dual sp2004 run it hits 49c.Idles at 34.
