AirPods (and AirPods Pro [and AirPods Pro 2nd generation]) now available
11 May 2020
Is it normal for noise cancellation to feel slightly uncomfortable if nothing is playing?
Feels like someone is pressing their fingers in my lugholes.
yes. I also don't particularly like that feeling and can't wear it for long time. Although I tried it with the sony in ear buds and not the apple airpod pro. They are meant to have a mechanism to release the pressure when you initially put them on and generally feedback from it has been positive.
23 Jan 2005
okay i want a set and the only thing between them is the standard legs look too long i like the length of the pro legs but i don't need the anc of the pros, any help one way or another ?
Thanks
Commissario
16 Oct 2002
In the radio shack
When you’re using them, you can’t tell how long they are, they have no feelable physical presence. Also, when you’re using them, you can’t see them either so the length is irrelevant.
If you don’t need or want the anc, go with the non Pro versions.
14 Sep 2009
Northumberland
Can't comment on the standard ones, as I gave the set I got away. However, on the Pro, you can barely tell they're there. Snug on the ear channel, but that's it. I guess it's dependant on what fit you're after and whether you want ANC, as Feek says. :)
Couldn't recommend them enough though. Really have converted me to wireless headphones with their good sound and the ability to seamlessly move between my MBP and iPhone.
23 Jan 2005
just got a price match from JL against **** but get the 2 years warranty with JL
Man of Honour
29 Jun 2004
Oxfordshire
Have the XM3 in ear from Sony but going to get a pair of these now they have auto switching. I have two MBP’s and an iPad Pro that are all used for work and have Slack on all 3, depending on what I’m sharing means I often make calls between all three, so to have the Air Pods automatically switch makes my life so much easier rather than manually having to switch the headset between devices
14 Oct 2009
UK
The left airpod of my missus's airpod pros has stopped charging and when its in the case it just keeps flashing up on her phone going from 1/2/3% then disappearing again. Tried to clean out the case and the airpod itself to ensure its not a contact issue. Contacted Apple who suggested taking it into a store but no appointments near me other than one at 11am on a Thursday in central london (I live out in Kent)
Fully reset the airpods and the phone also!
Anyone got any other suggestions?
24 Jun 2008
If they are pro’s It must be in warranty - call apple care back and ask for a DIY repair.
they place a £79 hold on a card incase you don’t return the old one but you get a replacement within 48 hours usually
14 Sep 2009
Northumberland
I have a set on INAIRS on my old UE900's. I haven't tried them on the AirPods Pro, so not sure if/how well they fit. I can say that you get incredible isolation with them though.
