1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Akasa screws don't fit their fans?
Discussion in 'General Hardware' started by Mortah, 5 Jun 2006.
  1. Mortah
    Gangster
    Just bought 2 120mm akasa fans for my new system... but I'm having trouble putting the screws provided with the fans into the fans... basically they are too wide! Unfortunately standard screws don't hold it at all! any ideas with what to do? :confused:
  2. Phil99
    Capodecina
    Screw them in harder, they should bite in to the plastic....mine were very hard to screw in but got there in the end :)
  3. Mortah
    Gangster
    Ta, thought that might be needed... just wanted to double check :)
  4. utajoker
    Capodecina
    yeah they are realy hard to do, i didnt bother an jus bluetacked em in :p
  5. Dureth
    Wise Guy
    The screws are tight because they are self tapping, meaning that they make their own hole (in a way, very generalised there).
    Don't worry its meant to be like that, just screw harder.
  6. TheOracle
    Capodecina
    Yes, they make a nasty crunching sound when they go in.
  7. pinkacidbootson
    Mobster
    I love that sound it makes :p but yes it is quite difficult and time consuming!
  8. SinaiSound
    Mobster
    Before I put my akasa 120mm ambers in my P180, I put the screws in before mounting the fans in the case, that way I could thread them into the fan whilst holding them in my hand, rather than messing about in the case.
  9. Global_Inferno
    Hitman
    Be carefull not to strip the thread thou! ;)
  10. The $6m Dan
    Wise Guy
    That is genius, it should help dampen any vibrations from the fans too :)
    I was looking at getting some of the rubber fan mounts, but the postage almost triples the cost, lol. BluTak it is :D
  11. SiriusB
    Capodecina
    I hope you haven't blu-tak'ed your HSF in too :p
    SiriusB
  12. t31os
    Mobster
    I wouldnt recommend blue tacking any fans, fans vibrant, and vibration means they will in time come unstuck, risky if you have expensive parts by or around the fans.
  13. Slyman2k4
    Hitman
    try rubbing the end on a damp bar of soap. Makes the job a hell of a lot easier.
    If someone already suggested soap, sorry :p
  14. ErNciLator
    Wise Guy
    kinda sounds pervy this topic; screwing harder ;).
  15. pinkacidbootson
    Mobster
    Thats the way to do it! Just make sure they go in straight!
  16. utajoker
    Capodecina
    well my fans are holding strong with blue tak they even quite difficult to pull off, mostly due to the amount of bluetak i used :)
  17. monkeypants
    Mobster
    Haha, I didn't really think anyone wouldn't think of this. I did it when I ran out of fan screws and it worked fine, didn't really notice any dampening though... possibly because I didn't try the fans without the blu-tak. :o
  18. Mikey1280
    Wise Guy
    How about a combination of blue tac and screws. The screws partially in to stop the fan vibrating and falling off, and the blue tac will prevent vibrations and extra noise.
  19. ferrettoes
    Gangster
    I found that...
    A little tip for fitting them:
    Use the screws provided and prescrew them into the holes in your hand before placing the fan into the case. Screw them in a few turns then turn them the other way to clean the plastic out then go back in for a few more turns then repeat until their nearly all the way in. This makes it loads easier once you go to fit into your case. Worth the extra effort as its alot harder the other way.
