Hi,
At the moment I just have one echo device and the £3.99 sub along with my Prime account.
With this I listen to almost anything I like on the Echo but when I try to create a playlist on my laptop I cannot access all the songs that I want to create my playlist (message says your sub only lets you listen on one device etc.) and it's a very slow process creating a playlist using the Echo is there any work around for this?
Only way I can see is to upgrade then create playlists then downgrade back to single device.
