- 16 Feb 2009
Hopefully this update comes to the Desire
Borich
Borich
The way Google is looking to do it is locking it to your account, so you can still use them on your new phone, but have to be logged into your account to do so, in a similar way to the way purchased apps from the market are linked to your account. This model is far from perfect, buts its better than linking it to a single phone and not being able to transfer them when you get a new phone IMO
If apps2SD does go ahead I can see a lot of devs switching to the add supported model and distributing the apps free, which is a shame as the dev's loose out on funds and the ad companies make more
Wait, what?
Does that mean if you buy an app for one android phone and subsequently get a new phone you currently have to buy the same app again to use it on the new one?
One massive step backwards if that's the case and something that would definately keep me with WinMo for the foreseable future.
Wait, what?
My hero can tether Just press two buttons and it is on. Is it something to do with other phones?
Errrrrrr..... no, he's saying that app purchases are registered to your Google account, which means that you can download and install whatever apps you like on whatever phone you like as long as you're logged in with the correct account.
Google Android Market currently remembers your paid-for apps when you sign in, allowing you to download them again onto any phone you are signed in on, for free. If the apps were locked to the IMEI as was suggested you'd be correct, and that would be a huge step backwards.
From what I understand each paid app would be unique and signed to your account, so only your account would be able to use it, similar to music DRM
Ahh, ok, it's just you stuck a "would" in there which implies it isn't available yet...
[TW]Fox;16432218 said:Dunno, everyone is telling me the Desire wont do it unless you use a cable or some third party app?
that sounds correct afaik. i know the Hero requires a 3rd party application, which is the same as with any blackberry, iphone, winmo phone - only nokia seem to support wifi tether 'out of the box'
Winmo does too. Or least my Omnia did so out of the box.
You can tether the desire and N1 by using a third party app and the same program on your computer. You have to connect the two with a USB cable.
I think you're wrong, it can be done by simply connect it via USB and enabling Mobile Network Sharing can't it?
Well not on my Nexus. I'm assuming the Desire is the same. I'm not saying you're wrong though!
Also, what would the need be for the apps if it could be done natively?
for desire you need to install htc sync, then select internet sharing from the options you get when you connect the phone to the pc with the usb cable.
guess no one read my post last night about tethering, wanted to know if you could remove htc after its installed the required driver and what not or do you have to have it installed to use tethering every time(i.e. is htc needed to be installed just for the drivers or does it have something that is required to have it installed to use tethering)?
I was testing on my dad's netbook so wouldn't be syncing my phone on it, my dad has no use for htc sync so I'll be uninstalling it, so was wondering if I wanted use tethering on it in the future would I have to reinstall htc sync on it.
