1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Antec 902 front panel please help
Discussion in 'Case Central' started by Thrill, 31 May 2010.
  1. Thrill
    how do i take the front panel off of the antec 902, please help? im having real trouble taking it off, and not sure if it even comes off? i've kinda bent all the lugs trying to take it off and is now a pain to get back on? although ive enver hda it fully off, only the bottom few lugs off.
    please help, i need to take the front panel off.
  2. MiNxYyY
    PermaBanned
    not sure if its the same as an antec 300
    but for the 300 you have to push the 2 black pins on the inside of the front panel to clip them off.
    Once they are pushed in, the front will just slide off :)
    Can you take a photo and show us the front panel from inside the case? and also the damage you have done :p
  3. Thrill
    Ive had all the front off, but it gets stuck nearer the top. its like wedged in. i've pulled down with all my strength and it doesnt budge. there isnt any screws on the inside, i've checked. no damage is done, its just the black pins and slightly bent as i took it off and then forced it back on.
    basically, theres big black pins that are pushed through the hole. if i push all the pins through, right up to the top. it still doesnt come off.
    cheers :)
