1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
any plumbing/mechanical or electrical engineers (help please)
Discussion in 'General Discussion' started by cm1179, 15 Mar 2010.
  1. cm1179
    Mobster
    i'm doing a college assignment and need to produce a specification for the installation of an intrurder alarm, fire alarm and an airconditioning unit (in one room). i'm struggling, can anyone please provide me with a necessary spec, manufacturer name, contact, bs etc? for a small building. works are only on the ground floor
  2. Swifty55
    I'd quit your college course right now...
  3. JBuk
    Capodecina
    This, you're obviously not cut out for it if you can't do something simple
    and do your own work tbh :)
  4. Beerbaron
    what course are you studying?
    surely you can just google burglar alarm installation guide etc
  5. Matutu
    Hitman
    For the AC unit look at a small wall mounted Mitsubishi unit, cant go wrong, and also you can get the condenser/evap etc from them as well.
  6. Amp34
    Caporegime
    Are you looking for an electrical engineer (someone with an electrical engineering degree) or an electrician? :confused:
    It looks like the latter I assume?
  7. cm1179
    Mobster
    i can do it on my own but as i'm neither an electrical or mechanical engineer, i'd simply get it from a previous tender spec
    however, i thought by asking on here it might be a bit more interesting in terms of options. obviously not.
    i could understand the comment of ''i'd quit the course now'' if i was studying mechanical or electrical engineering only, however, i'm not.
  8. mitch212k
    Hitman
    I will be a mechanical engineer as of summer 2015?
  9. Bubo
    University of Wickes?
