1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
are all audi 1.8t 20valve??
Discussion in 'Motors' started by keef, 9 Jul 2006.
  1. keef
    Gangster
    title says it! :D
  2. penski
    PermaBanned
    No it doesn't.
    *n
  3. Scuzi
    Man of Honour
    Yes, they all use the 20VT engine as do all the 1.8T VW's, Seat's and Skoda's. They come in different states of tune though ranging from a measly 150bhp up to 225bhp.
  4. keef
    Gangster
    yes it does, are all audi 1.8t engines 20 valve?
  5. Scuzi
    Man of Honour
  6. [TW]Fox
    Man of Honour
    Ranging from 150bhp to 240bhp you mean ;)
  7. keef
    Gangster
    cheers scuzi, :) just wanna check before i order some bits for the mrs car, what are the best vag group forums> or any place for info on the mrs a6 quattro?
  8. keef
    Gangster
    what has 240?
  9. [TW]Fox
    Man of Honour
    Audi TT Quattro Sport.
  10. Scuzi
    Man of Honour
    Which one is 240bhp? :o Is it the Audi TT?
    EDIT: Ahh right, thanks. Didn't know about that one.
  11. keef
    Gangster
    bet that flies then! how much do they weigh?
  12. Randell Floyd
    Wise Guy
    *cough*
    My 1.8T is 240bhp too :p
  13. keef
    Gangster
    i have the revo software on the wifes and was looking for a bigger turbo to put on it, any suggestions?
    do you have the skoda, i got smoked by one of them today in my mates fiesta rs turbo!
  14. Randell Floyd
    Wise Guy
    I have the Octavia vRS, very capable car in a straight line now it's running around 240bhp.Many a car it mocks now that dont expect it, I've been up agaisnt a few RS and they dont even stay in the rear view once the cars off, it had a S2000 a couple of times now so thats the kind of speed once rolling the car can achive.
    Bigger turbos are usually K04's or IHI by the likes of Jabba etc, but usually it's not just the turbo that needs to be looked at when going for any serious power gains.
    One guy on Briskoda now has a 4x4 1.8T thats going too be running around 500-600bhp depening on what they can run it safely at seeing as it's a first for the skoda, the TT and r32 have had around 650bhp :eek:
  15. keef
    Gangster
    he he he, looked at the octavia for my wife but couldnt afford one! :(
    if i wanted a bigger turbo, bov etc what else would i need?
  16. Randell Floyd
    Wise Guy
    Depends on what you want........Jabba has 3 stages for the IHI...stage 3 kit comes with everything...exhaust manifold, turbo, 3'' downpipe, big injectors, upgraded fuel pump, new oil lines for turbo, fitting kit, induction kit, remap, boost controller etc...can't remember if FMIC is included or the cat.
    Fitted you are looking at a minimum of £5k.
    Stage1 has an adapter plate fo rthe exhaust manifold to allow fitment of IHI.
    Can't remember of what Stage 2 is.
    Check out the Jabba site for details or give them a call.
    For stage3 at minimum boost you'll get approx 280bhp and 340bhp for max boost.
    Having the internals done will see max boost power rise to approx 360bhp and 340+Nm.
    The cost of having the internals done will easily double the final price....it's due to the amount of labour involved.
    You can get a K03"S" replacement or an E05 which will give around 280bhp. Bear in mind though the E05 will require new oil pipes for turbo, 4BAR FPR, remap....it would also be wise to get a FMIC.
  17. keef
    Gangster
    gonnalook on jabba website now noob q, whats fmic?
  18. Randell Floyd
    Wise Guy
    Front Mounted Intercooler, essential on anything over the 250bhp mark, even more so if you live in the warmer parts of the UK. Thats the benefit of living in North Wales :D
  19. keef
    Gangster
    got ya! ;)
  20. keef
    Gangster
    i have the m5s gearbox, at what point would that want replacing?, and i dont need when its broken! what kinda bhp would kill it?
