1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Competitor rules
    Dismiss Notice
Artifacting on stock settings
Discussion in 'Graphics Cards' started by Boozebeard, 20 Apr 2010.
  1. Boozebeard
    Wise Guy
    I just got one of those new asus 5850's and I'm getting black squares flashing on screen playing bad company at stock settings. I've even tried putting the volts upto 1.2 with stock speeds and still artifcating. Help me.
  2. layte
    Wise Guy
    Sounds like you might have a a duffer. What card did you have before? If it was a V one did you remove the drivers before installing the ATI?
  3. Boozebeard
    Wise Guy
    It was a 9800gtx and I did remove the drivers.
    No artifacting playing crysis warhead with the card set too 900 core 1.2 volts.
    :confused:
    Why would it artifact in one game and not another? No artifacting using furmark either.
  4. Boozebeard
    Wise Guy
    Really confused now. I took the clocks down as low as they can go in smartdoctor.
    550 core
    750 mem
    And not only did I still get artifacting but the game was running at exactly the same frame rates as when It was at 900 core. CCC and Afterburner both report it is running at the correct speeds. I have no idea whats going on.
