- 13 Jul 2009
Hmmmn got me worried about buying a DirectCu version now... think I might wait.
Maybe a bios flash on ur DirectCu 5850's is needed to the standard Asus 5850?
Is anyone trying crossfire? is there a way to overclock both cards as I dont see a option on SmartDoctor for that?
Im now running crossfire using reference design and new design. Thankfully with the new card top and old card bottom (i assume it would better for heat this way as heat rises, although bottom card is cramped ). MSI afterburner is allowing me to clock both cards same time. Also both cards are using fan speed correctly so both increase fan rpm as they get hotter at the correct amount. Newer card running a bit cooler. Havent tried core voltage yet or memory. Got to go back to work.
