1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Asus A8N32-SLI Deluxe nForce SLI X16 (socket 939) Problem
Discussion in 'Motherboards' started by Bong-Master, 12 Jul 2006.
  1. Bong-Master
    hello all this is *** i have got (x2)
    Corsair 2GB DDR XMS3500LL TwinX (2x1GB) CAS2 (MY-107-CS)
    AMD Athlon 64 X2 Dual Core 4400+ (Socket 939) - Retail (ADA4400CDBOX) (CP-127-AM)
    Asus A8N32-SLi Deluxe nForce4 SLi X16 (Socket 939) PCI-Express Motherboard (MB-118-AS)
    With a GForce 7900GT (256mb)
    the psu i use is a X-Power (ATX-700TW)
    my monitor is a hanns.g (19" TFT)
    O/S Windows xp home (sp2)
    sata 250gb maxtor HDD
    This is my problem The dam thing just shut's down(does not do a re-boot).uppon re-booting (hitting the button to turn it on)there are no window's errors (send error report box).
    i have re-built the pc from scratch again just to make sure i did have every thing in the right place & i did wooohooo but the still it shut's down.
    the cpu is running @ about 45 c.
    any help with this problem would be very help full.
    Many thanks Bong
  2. Arthalen
    Wise Guy
    First place to look could be your PSU.
    Sudden shutdowns can be related too:
    PSU: Faulty - Not outputting enough wattage to supply the system.
    CPU: Heat - could be overheating - the shutdown happening in games ?
    O/C: You might need a bit more voltage to get it stable if you have it overclocked.
    M/b: Power Regulators might be overheating causing immediate shutdown. Check the temps of your northbridge/mosfets
    Just a few idea's to get you started.
  3. Bong-Master
    how do i check
    it shut down either in game or just after coming out of game
    I dont not have the system over clocked.
    any thanks
  4. w3bbo
    Man of Honour
    What is your cpu temp under load? 45c is a little high if thats at idle. and iirc the A8n32 has a default shutdown temp of 60c for cpu which could well be the case if your idling at 45.
  5. Bong-Master
    id say about 45-50 but it also shuts down on desktop
