After suffering from my Orange Livebox losing connection occasionally and getting very laggy in WAR instances I decided to upgrade to a new Wireless N router. I needed a print server, so settled on the Asus one (even though it had mixed reviews), but it's had new firmware, which users have said solved their problems.
Anyway I've been able to set it up and update firmware and connect to Orange, but it's giving me some headaches.
It fails a couple of its in built diagnostic tests i.e.
Test ATM OAM F5 segment ping and ping gateway both fail.
Only a few web-sites will open, e.g. google. But others wont open at all.
Xbox Live works fine, but WAR or Steam wont connect!
Any Ideas?
Any Ideas?
