ASUS P5Q Premium Chassis Intrusion about 6months everything went fine and now the stupid motherboard says in every reboot Fatal Error Chassis Intrusion unless I clear the CMOS using the jumper (and turning the power off) in which case selecting [F2] to load defaults continues fine I have replaces the CR2032 Li battery I have reflashed in DOS mode the BIOS with the latest version reseller wans me that a replacement takes 4 weeks that's in Finland /&%#%¤#&/#¤/&% (rest is censored) Any ideas? Is this phenomen old news to someone? AND I have not yet overclocked the system: Intel Q9550, 2*2G RAM 800MHz, DVD+-RW 2layer SATA, 3*Seagate 1,5TB Sata HD which reminds me that the system can't find the 3rd HD and it once lost even the 2nd one #
No wonder it was not found on the BIOS: IT WAS A "MISSING" JUMPER PROBLEM and it required just one more CMOS reset in order to recognize the "new" jumper while changing the cables one of them removed the jumper I check how it works for a while and then - if everything is well GLUE the jumper in place
