1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Competitor rules
    Dismiss Notice
Athlon II Max Vcore 24/7
Discussion in 'CPUs' started by Frozennova, 8 Apr 2010.
  1. Frozennova
    Man of Honour
    Simple question cant seem to find the answer anywhere. Whats the max safe voltage on the Athlon II chips for 24/7 usage.
    Building a budget rig for the misses, So I'll get some results up once she's sorted the rest of the money for the build
    Gigabyte GA-MA78LMT-S2/ Athlon II 240
  2. Big.Wayne
    Capodecina
    Dunno what the max safe voltage is? . . . I've been using 1.55vCore for several months and everything seems fine! :) . . . . Not seen temps much above 55°C at extreme loads . . . normal full loads are sub 40°C most of the time (Air) . . .
    On the UnderVolting side of things two Athlon™ II's that I've tested have both run a mild overclock using 1.200vCore (1.425VID & 1.350VID) :cool:
    Athlon™ II X2 240 . . . . give it hell! :D
  3. Frozennova
    Man of Honour
    Thought i'd be hearing from you.
    I'm hoping for around 3.2 but thats optimistic as its going to living in an asus ta-861
    i might try and squeeze a coolit eco in there if tubing will reach the front of the case, so I can have it folding
