It is yes. but they might void the warrenty.
It don't look that bad at all. plus when it's in the case, you dont even see the sticker.
Hmmm, what settings did you have when using the 5970 ?
I tried the 480, and found the 5970 to be much better card.
I guess we all have are own views
Be interesting what settings you had in the CCC.
In mine i set it as,
AA- applications/ with filter set to (box) (as there is no need to change this to anything else, i.e Narrow-tent etc, as it kills performance. having this set to box, didn't change the quality in my eyes.
AF- applications
AI- standard.
Midmap Detail- Quality
Anti-Analising Mode- Quality (which is supersampling)
Then maxed in game settings.
Runs exellent
I have always used nvidia cards. since i tried this ati, made me relise there is to much going on in the nvida control panel compared to ati CCC settings when all you got to do in the CCC settings is choose 3D, the click all, then change the setting like i said above, all to whatever you like.
Just found it less confussing
I think some people will have problems if not set up proper in either CCC or nvidia control panel.
I just think from losts of testing, the 5970 is the better card.
But hey, we all have are own views
I also tried a 5850 with the 5970.. blimy, that kicks ass
Cheers.
