If default clock is not 735 then it aint an OC edition so RMA is in order ...
Two right great card tho.
I'll ask if they can send me the oc one.
My sapphire 5970 oc runs @ 1.15 volts for 900/1250, it will get to 990 core @ 1.3 vcore but is not entirely stable until I get it below 950 which it can do even with vcore down to @ 1.23v so something strange there - I have a corsair HX1000 psu so that should be OK but maybe it can't really push the amps needed through the 6pin + 8pin which makes it flakey at higher clocks/voltage???
Hey ninja.
What Fan speed you running at ? or are you set to auto with them clocks ?
Cheers mate.
On auto it always hits 95c cos that is what the bios allows it to get to before hitting the higher fan speeds Proably causing slightly earlier failure just out of warranty for the higher average temp
Using a custom profile manages this better ..
I use a fan profile with MSI afterburner ... and for comparison purposes I Just did a run with Unigine Heaven 2.0 where the ambient is 19c at the lower case fan intake area ... this is with a Vapor-X 5870 right next to it on a Gigabyte-X58-UD5 for tri-fire goodness GPU1 is the 5870. These are my everyday 24/7 settings and you can see the fan speed relative to temp
Cool.
I tried my 5970 with a 5850 gives you some nice boost.
I couldn't get the fan to work on afterburner. so i could set it to what i like, so i clicked settings, then under master graphics processor selection, click GPU2. and that allowed me to set it to manual, if i liked.
95c wished mine would clock better. i go up 5 MHZ and she don't want to know.. hopefully my next one will be ok
