1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Aux-drive-belt tensioner failure!
Discussion in 'Motors' started by taximike, 26 Apr 2010.
  1. taximike
    Hitman
    So - was 2 minutes away from work. Battery warning light came on. No other symptoms, on the motorway. So as a precuation I turned off all lights and stereo/air con etc.
    Come off at next motorway exit - engine overheats as soon as I stop at lights. Power steering dies. Luckily office car park is literally yards from the motorway exit so pull into a space right by the gate. Remove engine cover - as I suspect - drive belt sitting on the undertray - tensioner in bits!
    [​IMG]
    Uploaded with ImageShack.us
    So - should I fix it myself or get it towed to a garage? It's sitting in the office car park at the moment! You can see the tensioner in bits!
    EDIT> Car is 2001 E46 318i 1995cc
  2. Dogbreath
    Capodecina
    That must have been making some horrible noises before it failed.
  3. Danm54
    Wise Guy
    Do it yourself but get a decent tensioner.
    Shouldn't take too long if you're handy with spanners
  4. taximike
    Hitman
    Yeah
    The only toss up is - car is under warranty. However have to pay £70 to get it towed to garage.
    How much will it cost me to do it myself? If it's a lot less than £70 I'll just do it - looks fairly straightforward in the Haynes manual. But I think I might need a whole tensioner/pulley assembly and I can't find anywhere in the UK selling that!
    It made no horrible noises at all before breaking! Honestly! I'm normally pretty sensitive to odd noises!
    Sam
  5. Moeks
    Sgarrista
    I would think the belt and tensioner would cost £70 or more, you'ed need to check though to be certain. If it's under warranty just get it fixed, I don't think you're going to do it for any less than the tow cost really anyway.
  6. BigglesPiP
    Capodecina
    Will the garage not pick it up?
  7. taximike
    Hitman
    Nope - that's part of the deal with the "warranty".
  8. TaKeN
    Capodecina
    Thank yourself lucky that the tensioner is in an accesible location.. mine needs replacing and its about 10mm from a solid piece of car.. :\
  9. Matt82
    Capodecina
    id get it towed incase it killed anything else
