Sorry, I'm all wired apart from the laptop so no idea.Would you reccommend the Belkin F5D7001uk 125mb/s Wireless PCI card to go with it?
toy_soldier said:How can you tell which version of the firmware it will ship with?
Thanks
There is a little sticker on the bottom of the box. The latest says "ver.1144uk" and that ships with the .17 firmware.How can you tell which version of the firmware it will ship with?
Richdog said:Well, bought the router and wireless card and everything seems to be running great! Router was a piece of pees to set up but the wireless card gave me a few teething problems when setting up the security, couldn't quite get it to connect for 15 mins or so.
Signal seems very stable however, and I shall tell thee all tonight whether it survives an evening with no drop-outs or not.
By the way, how do you tweak this snr or attenuation things, can someone tell me how please?
EDIT - Grrr still having issues getting my comp set up using the network card...
Wingz said:1. Click on "Start" then "Run" then type cmd
2. when the Black Dos window popup type "Telnet 192.168.2.1"
3. it will then ask you to login so use for Login type admin and then the password you set for the router, if you not set a password then leave it blank.
4. once logged in type "adsl configure --snr 20", the router will then resync and you should be connect to a higher speed.
Cozman said:well my snr @ 40 actually reads 4.1 here ... & i was passing on info from what i believe to be an informed source but of course someone who posts a lot isnt always right but the guy gets a lot of praise on adslguide
my understanding is ... the snr tweak doesnt change anything on the line but it fools the BT exchange into believeing you have a better quality line than they normally assume ... so technically you might call it a hack rather than a tweak ... either way it does do something that has boosted my connection by at least 1M/b so far probably closer to 2M/b
Cozman said:i though would be that simple but apparently it isnt or so im informed by others (full sync but limited speeds are common)
ive never synched below 7180 in the 6 weeks ive had max but according to one of the line checkers (realtime check ill get link if peeps interested) my line is only allocated at 5500 max
