Belkin Wireless PCI Card - Disconnecting
12 Jun 2005
St Albans
I recently installed a Belkin Wireless PCI Card to my sisters computer using the latest drivers. All seemed fine at first but it started to get into the habbit of disconnecting. Whats even more strange is it never has an 'Excellent' signal, but of the time its low. This is strange since the router is in my room which is next door? Our laptop nearly always has an Excellent signal, even at the bottom of the garden. When it loses the connection you normally have to Disable the PCI Card in device manager, and then the wireless connection, then reenable otherwise it will not find the router. Can anyone think of a solution?
17 Dec 2005
I have just installed one of those today in my new pc. A couple of time it has connected fine with excellent signal but now when I boot up it just wont pick anything up.
I might try and return it if i can't find out what the problem is.
7 Nov 2005
Southampton, UK
I'm pretty sure that belkin shipped a load of V7000_3s qith the wrong drivers. Take the card out and have a look at the sticker on it to make sure your getting exactly the correct drivers, I had exactly the same problem becuase I was using the ones for version 4 and I had version 3 of my belkin card...infact ditto that for 4 other PCs!!
