1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
BenQ G2410HD 23.6" and BenQ G2420HDBL 24"
Discussion in 'Monitors' started by Nemesis379, 16 Apr 2010.
  1. Nemesis379
    Wise Guy
    hi,
    both the products below are at a good price.
    but can anyone tell me what response time is?
    and does it really matter as much?
    also which is better between the two?
    also is 24" better than 23.6". because since there so close, is there any difference? or just a tiny bit shorter
    BenQ G2410HD 23.6" Widescreen LCD Monitor
    http://www.overclockers.co.uk/showproduct.php?prodid=MO-030-BQ&groupid=17&catid=510&subcat=
    BenQ G2420HDBL 24" Widescreen LED Monitor
    http://www.overclockers.co.uk/showproduct.php?prodid=MO-033-BQ
  2. rexehuk
    Mobster
    Personally wouldn't go with BenQ again... £800 panel died after 3 years just after warranty. But I cannot fault the monitor during those three years!
    But yeah those monitors are very different. 23.6" is LCD and the 24" is LED which would give you much deeper blacks if you enjoy watching movies a lot. Personally id go for LED as it's a newer screen technology. Even though there is a 3ms different in timings, I wouldn't let that bother you, as you wont notice it. I imagine games look very nice on the LED 24" :D. Now you just need to buy two more and have an LED eyefinity setup :)
  3. VeNT
    Capodecina
    not sure how different the size is but I've the HDBL and it's really nice.
  4. Nemesis379
    Wise Guy
    mm...ok thanks for the advise
    but what an eyefinity setup?
