1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Best 1TB hard drive for data and image backups
Discussion in 'Storage Drives' started by Sunbed, 26 Apr 2010.
  1. Sunbed
    Mobster
    Hi folks,
    Is the Samsung F3 still a favourite? I need this drive for media and backing up regularly using Acronis. Any preference?
    Thanks
  2. aowc02
    Gangster
  3. Devrij
    Capodecina
    I'm still happy with my F3 for what it's worth, but it could be worth going for a green series as posted above if you don't run apps off it. However, if you have the spare change then a faster drive will speed up those acronis transfers.
  4. mrfun1981
    Gangster
    Iv got a F3 & think its great, but as the post above side if you are not running app's on there it might be worth getting a Green drive & saving on the power you use
  5. aowc02
    Gangster
    If you are looking for more performance, id also give Western digital's other brands / series a look.
    The black for instance is a great high performance drive :)
  6. apocgohan
    i'd also rate the WD caviar black, brilliant for combining quality and storage.
  7. oli356
    F3 or the WD one would be fine!
  8. Sunbed
    Mobster
    Thanks guys. Will prob go for F3 or WD green. Most likely Samsung, as I have owned WD, Seagate and Hitachi HDDs - time to try something new :)
  9. Reldar
    Gangster
    I would personally choose WD Green. Uses less power and runs cooler.
    If you're only storing media and backing up there isn't much point of picking a higher performance drive.
  10. Simon42
    Hitman
    Another vote for the WD Green - the latest advanced format ones have very impressive speed for a 'green' drive.
