1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Competitor rules
    Dismiss Notice
Best bang for buck graphics card
Discussion in 'Graphics Cards' started by edger, 14 Mar 2010.
  1. edger
    Gangster
    Hi guys, been out of the game qutie a while. Just looking at graphics cards and wondering what the current best "bang for buck" card is, i.e. is there one thats reasnoably priced i.e. £150 or so, and yet can be overclocked to beat its siblings?
    I also have one requirement, that is it vents its hot air outside the case (new pc has a v small case with not much airflow)
    Finally will this card offer a decent improvement on an 8800GT?
    Thanks!
  2. bells
    Hitman
    5770
  3. Sindri
    Hitman
    If you intend on keeping the case then a 5770 may be your only option, its unlikely a 5830/5850 would fit. Furthermore both the 58 series cards exceed the 150 mark.
  4. V4nger
    Hitman
    get the Sapphire Vapor-X version of it. it should stay cooler in the low airflow of you case.
  5. edger
    Gangster
    Thanks for advise so far seems to be a general consensus towards the 5770. I dont think size will be a prob as the 8800gt I have now is huge and fits ok, but I only have one PCI-E power adaptor (without changing the psu).
  6. Fatboy
    Don
    5770 Vapor X will be the best value for money.
  7. RobotXander
    Wise Guy
    How about a 4890? Fantastic performance. I have yet to push mine on my 22" 1080p monitor.
    They can be picked up pretty cheap now I'm sure?
  8. Sindri
    Hitman
    If you are getting a 5770 then i would advise that you considered the Asus Cucore version, the voltage tweak technology will allow a decent overclock.
    The custom cooler is highly efficient too so your poorly ventilated case is unlikely to cause it problems.
  9. sanofi
    Wise Guy
    How does the 5770 stack up againts a 512mb 4870?
  10. Roll
    Mobster
  11. Azuse05
    Wise Guy
    Oc still have afew of the xfx ones that vent out the back but not many. The newer ones don't in which case the vapor-x is without doubt the best option for a low airflow case (like mine :)).
  12. KoN1ch1wA
    Mobster
    I upgraded from an 8800GT to a 5770 Vapor-X and I can tell you it is definitely worth it, best bang for buck for sure.
  13. Ch3m1c4L
    Mobster
    your aware that an 8800gt is a tiny card compared to even the high end 8 series cards, let alone the high end ati 5 series.
    So yea, 5770 *** :)
  14. Sukh
    Mobster
    Vapour X are nice and cool, but throw out all the heat into your case, so might not be the best!
  15. Bane
    Mobster
    Out of the 5770 range, would this be a big drop in performance? A Powercolor Go! Green HD5750 1GB GDDR5 (Product Name : AX5750 1GBD5-NS3DH
    I think this is the one Powercolor has replaced the voltage chips on, or something like that, so it doesn't require AUX power cable. But it does has reduced core and memory clocks, 700 and 1150 MHz
  16. Kharbyne
    Gangster
    Will it fit?
