1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Competitor rules
    Dismiss Notice
Best card for old motherboard?
Discussion in 'Graphics Cards' started by j98, 4 Aug 2006.
  1. j98
    Hi! I have an Asus P4T533-C motherboard with a Leadtek Geforce 4 Ti4200.
    Does anybody know what is the best possible card that will work with this motherboard? Would it offer much of a performance increase? I only really play WoW lately but I have to turn the graphics down quite a bit for it to run properly. Is this likely to be a limitation of the Ti4200 or the 2.26ghz cpu?
    I'm hoping there's a card available that will squeeze a bit more life out of my poor old pc!
  2. Cyber-Mav
    Capodecina
    if its got agp 4x or 8x slot then you can get gainward 7800gs+ which is basically a 7900gt.
  3. Tetras
    Mobster
    I'd have thought WoW was quite CPU and memory intensive, but anyway, anything like a 9700 Pro or above would be a good boost and suitable for the P4. I don't think I'd go for anything better than an X800 / 6800 for that CPU, even a 6600 GT would be pretty good or an X800 Pro/GTO.
    There are 7600 series cards on AGP soon too which'd also be worth a look, not sure how far away they are though, but (hopefully) will be good value.
  4. j98
    Thanks for the suggestions! I think it's only AGP 4x...
  5. j98
    What about these?
    Sapphire X1600 Pro 256MB DDR2 AVIVO TV-Out/DVI (AGP) - Retail (GX-116-SP)
    Sapphire X1600 Pro 512MB DDR2 AVIVO TV-Out/DVI (AGP) - Retail (GX-120-SP)
    Would they be any good? Does anyone know if they support agp4x? I can't find out if they are both 4x and 8x or whether they come in two separate configurations??
    :confused:
  6. LoadsaMoney
    Caporegime
    I think any AGP card will work in either 4x or 8x as the differnace between them is nothing, x1600pro is a terrible card.
  7. t31os
    Mobster
    Search the forums.
    X1600 are not classed as being very good, though i've no personal experience.
    I'm not sure how much you're looking at for a decent AGP card, but if i had to advise, then i'd say save the money and spend it on an overall upgrade.
