I am looking at an Asus T3-P5G31 but it seems like it will only hold 2 disks... I am really looking to have 3 or 5 disks. Probably with a hardware RAID card and another gigabit NIC so I can also use it as an iSCSI target. I am looking for something that will be pretty good on power consumption as well. I intend on having the best power usage CPU in it. Thanks guys.
http://www.overclockers.co.uk/showproduct.php?prodid=CM-061-RY&groupid=701&catid=1428&subcat= this might help you if your short on internal space, could put a HDD in a similar cage or buy one like this - http://www.overclockers.co.uk/showproduct.php?prodid=HD-219-SE&groupid=701&catid=1240&subcat=941 Depends on your intent.. are you making an FTP if I may ask?
If you mean the case, then probably this one is your guy + of course some ITX board and other stuff around it - Chenbro ES34069. "Review" : http://www.logicsupply.com/blog/200...069-case-review-part-2-the-perfect-mainboard/
