1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Best USB and PCMICA 802.11g for streaming video?
Discussion in 'Networks & Internet Connectivity' started by MaX_PoWah, 1 Jun 2006.
  1. MaX_PoWah
    Wise Guy
    I have this router..
    Dlink Dl-624+ - Airplus Xtreme 108mbps 802.11g
    http://www.dlink.com/products/?pid=6
    I do already have 802.11b connections, but I since now I am wanting to stream off video and also mount cdroms from a secondary machine and access them from another. Im finding this impossible with what I have now.
    Would these 2 adapters allow me to stream video? Note, that I will be having a network with 802.11b and 802.11g adapters. So if I bought a product that says it will give an increase over g-rated speeds. Would I see it?
    Here are the products.
    BT Voyager 1060 Wireless Turbo PCMCIA Network Adapter (NW-001-BT)
    http://www.overclockers.co.uk/acatalog/Online_Catalogue_PCMCIA_Adapters_200.html - 3rd item down.
    Netgear WG111T 108Mbps Wireless USB2.0 Adapter (NW-074-NG)
    http://www.overclockers.co.uk/acatalog/Online_Catalogue_USB_Network_Adapters_220.html - last item.
    Sorry I cant link directly
  2. MaX_PoWah
    Wise Guy
    Sorry to bump this, anyone know?
  3. tolien
    Caporegime
    Possibly, but you're also going to see issues because of the 802.11b devices.
    Ultimately you're after one with the same chipset (if not brand) in order for the 108Mbps to work.
  4. MaX_PoWah
    Wise Guy
    Thanks for the reply?
    So to clarfy, I need all my devices to be dlink?
    Or can I just have 3 devices that are 802.11g, i.e router, pcmcia and usb, to get as close as 108mbps.
    If I get different brands, 108mbps just will not work?
  5. tolien
    Caporegime
    If you expect 108Mbps, yes.
    They'd all be sharing 54Mbps.
    Different chipsets.
  6. MaX_PoWah
    Wise Guy
    Thanks for the info, can delete or close thread!
