BFG 8800GTX - Audio over HDMI
12 Sep 2007
Wondering if anyone has their 8800GTX connected via HDMI and has working audio. I recently received the card and expected it would simply punt the audio over the HDMI like my on board ATI-chipset, but that doesn't seem the case. The nvidia settings are set as 'HDMI with Audio enabled' too.
Any suggestions?
Caporegime
20 Jan 2005
Co Durham
aint it the newer 9 series with the audio pins, im fairly sure the 8800 gtx dont have the audio pins.
Zotac made gtx8800 with an audio connector to give them sound over hdmi. Normal vanilla 8800GTX's did not have these.
Not sure if any other manufacturers did though.
24 Mar 2006
UK
You need to find the spdif output jumper on your audio card (even some onboard audio solutions have this), and find the corrosponding jumper on the graphics card, then connect them together.
You then get a direct audio feed to the TV, but you can't use the PC volume controls etc, have to change volume on the tv.
